430 Hydraulics
Theonn
06-20-2002 21:25:38
Where is the relief valve located on the remote valve attached to the top of the pump on a '66 430 case
Roger
07-02-2002 23:00:25
 Re: 430 Hydraulics in reply to Theonn, 06-20-2002 21:25:38
Klyde is correct. The relief valve is located on the pump INSIDE. To get to the relief valve, you will need to remove the top cover on the torque tube. The relief valve is on the pump which is attached to that cover. Set the pressure by using a hand pump with a pressure gauge and adding or removing shims.
klyde
06-21-2002 09:25:14
it's not. it's inside on the pump. (shoot that engineer)
Theonn
06-22-2002 17:51:14
 Re: Re: 430 Hydraulics in reply to klyde, 06-21-2002 09:25:14
that is no help.
