401 case 3 pt hitch
Doug Brown
06-20-2002 22:14:50
on my 401 case it wont lift high enough to pick up some 3 point hitch implements. how can i fix it to lift higher? Thank you
caseman-d
06-20-2002 22:46:24
 Re: 401 case 3 pt hitch in reply to Doug Brown, 06-20-2002 22:14:50
you using your third link. Just how high is it lifting??? Does it seem like the arms are coming up all the way, have you checked your fluid?? How is your linkage, have you tried to get more adjustment that way.
caseman-d
Robert
04-07-2003 09:08:02
 Re: Re: 401 case 3 pt hitch in reply to caseman-d, 06-20-2002 22:46:24
After I cleaned my hydraulic filter and refilled I had the same problem. I had to bleed the lines and continue adding fluid until the rock shaft would reach full height at the top of the piston stroke. Fully functional now, but I need to work on the down pressure valve now. I'm sure it's just worn or dirty.
Jeff
08-09-2003 08:20:42
 Re: Re: Re: 401 case 3 pt hitch in reply to Robert, 04-07-2003 09:08:02
I'm having the same problem with a 401 lift. The arms are traveling the right distance but the top link doesn't catch to lift the rear of the implement up, any good ideas would be greatly welcomed.
