Case 155
Grant
06-21-2002 00:20:32
I needed to replace the drive belt for my 38in. mowing deck. Did I have to disassemble the entire deck from under the tractor (all linkages etc.)?
Is there an easier way to drop the deck so I can slip the belt over the center spindle pulley? Any help would be appreciated, Thanks.
Ryan H
05-25-2004 19:24:39
 Re: Case 155 in reply to Grant, 06-21-2002 00:20:32
i also have a case 155 and it is getting all rebiult and it is a awsome tractor and the only way you can put that belt on is to put it on over te fan witch means you need to disconnect the pto and slip it over the fan onto the pulley.
