930
Speeds for Pulling?
Dan J
06-21-2002 11:04:14
I will be pulling in weight transfer pulls this summer with my 930 in the 10,700 and 12,000# classes. Can someone tell me the MPH of the lower gears or better yet does someone pull one and what gears do you use? Thanks, Dan
Roger
07-02-2002 22:47:34
 Re: 930 - Speeds for Pulling? in reply to Dan J, 06-21-2002 11:04:14
Dan,
Don't mean to "rain on your parade", but the power cell motors in the Case 30 series do NOT have the power potential of the 70 series. I have a 1030 with a turbo. Max power with the pump turned up is about 145 horsepower. The direct injection 70 series (970) with a turbo can easily exceed 300 horsepower. If you will be in pulls with serious speed limits, you may place. The speed in 4th gear is slightly over 5 MPH. Consider pulling in 2nd or 3rd depending on the hardness of the track.
Dan J
06-21-2002 18:32:57
John, The tractor is a 1968 and is stock, No turbo. 18-4/34 tires. I will be pulling stock classes. Thanks, Dan
John H
06-21-2002 19:18:40
 Re: Re: 930 - Speeds for Pulling? in reply to Dan J, 06-21-2002 18:32:57
Don't know if you can get it up to fourth in the 10,000 class, would be nice if you could. Third in the 12,000 class. We use to load my brother-in-law's 930 up to 15,000 and pull it in second gear. He had 38 inch rubber on that on. A friend had a turbo on his and he pulled in fourth. I know there are guys pulling 930's maybe they'll jump in with some hints for you. Good luck.
John H
06-21-2002 15:34:01
Do you have a turbo on it and what size tires are on the rear?
