Case 311B Quit
Help!
Mike
06-29-2002 10:22:07
I was using the old gal around the house to move large stones the other night. I shut her down while I loaded up the bucket (picking rocks), hopped back up and all I got was a click when I hit the switch. The batt is fine...I'm thinking maybe the solenoid? I tapped it a couple of times with a hammer thinking it might be stuck... but that didn't help. Anyone have any suggestions?
Zach
06-29-2002 19:59:47
 Re: Case 311B Quit - Help! in reply to Mike, 06-29-2002 10:22:07
the starter is jammed. pull the starter off and see if that helps. our 411B will do that. plus it don't take long to try it any ways.
Mike
07-16-2002 11:13:14
 Re: Re: Case 311B Quit - Help! in reply to Zach, 06-29-2002 19:59:47
Thanks...turned out to be some sort of wiring problem!
caseman-d
06-29-2002 14:12:19
Did you clean the batery cables and double check for loose connections.
caseman-d
Mike
07-16-2002 11:15:20
 Re: Re: Case 311B Quit - Help! in reply to caseman-d, 06-29-2002 14:12:19
Thanks Caseman - turned out to be some sort of wiring/ign switch problem. Turned the whole system inside out and replaced the switch. Runs like a dream again!
