1955 400 deisel case
max adams
07-01-2002 14:45:10
what i'm wandering about is,i need to change my hydraulic fluid and what i want to know is,what type of fluid do i use? is it regular hydraulic or ?. thanks for any help given. max
JG
07-05-2002 08:23:44
 Re: 1955 400 deisel case in reply to max adams, 07-01-2002 14:45:10
Before you put HyTran in take some HyTran and put a little water in it to show its reaction to condensation. You will never use HyTran again it is the worst Hyd. Oil on the market.
Irv
07-04-2002 20:52:24
I'd go with the Hy_Tran. You're probably only goin to do it once so put the stuff in thats made for it. The parts man at my IH dealership swears he's got several guys that had the other generic oil in, and had trouble, but changed to Hy_tran and it cleared it up. I've got a 62' 730 and I put it in everything, and it works great. Besides that, that old sweetheart of a Case is worth it.(grin) Hard to argue with buckmaster, though. Twenty years is a long time.
Just my opinion. Irv
whip
07-02-2002 05:08:25
Max,
you can getthe book from your case ih dealer .just ordered one for my 400
Pat T
07-01-2002 16:20:23
Max-
Owner's manual calls for ATF type A, that's not available any more but Dexron III or any of the Universal Tractor Fluids (Hy-Tran, Valvoline Tractor fluid, etc.) will work just fine. Takes 10 1/2 quarts, there is a cleanable hydraulic filter just below and to the right of the pto. Remove three capscrews and cover comes off exposing filter. Be careful with this, it's an edgewound paper filter and can be damaged if handled too rough, probably hard to find a replacement for. I'd suggest buying an owner's manual, really helps out with this stuff. Any other questions, just ask, I'm here to help out. Don't know a lot, but owned a 400 all my life so I ususally ain't too far in the weeds where they are concerned!! Good luck with your tractor and enjoy!!
Pat
Rich
07-01-2002 20:07:32
 Re: Re: 1955 400 deisel case in reply to Pat T, 07-01-2002 16:20:23
Hytran Yes, Dextron 3 No. Dextron 3 is to light of a Vis. grade. There is a huge difference in a Hytran or Hygard and a dexron 3 fluid. ATF fliuds type A are still available from Dealers if you ask for them.
max adams
07-01-2002 19:39:27
hey thanks pat, your right i do need a manual. do you know where i can find one? i tried yt but no luck.
maybe someone out there has one to sell? thanks again,max
buckmaster700
07-03-2002 17:28:08
 Re: Re: Re: 1955 400 deisel case in reply to max adams, 07-01-2002 19:39:27
try ebay for your book on your tractor u can change you fluid to regular hyd. fluid with no problem iv ran it in my 58 case 700 the same tractor as a 400 with a diffrent hood for 20 years universal hyd fluid from TSC will do fine
