580 B has antifreeze in the oil
Willie Ferla
07-03-2002 06:20:35
I get antifreeze in the crankcase. Do I need to remove the front end to remove the oil pan to check if any of the sleeves' O-rings are leaking? Also if I need to repair the engine, do I need to drop the front end in order to remove the engine?
The engine runs fine otherwise.
Zach
07-03-2002 12:40:36
 Re: 580 B has antifreeze in the oil in reply to Willie Ferla, 07-03-2002 06:20:35
its easier to i think but what ever you want to do.
Bars leak
07-03-2002 17:34:09
 Re: Re: 580 B has antifreeze in the oil in reply to Zach, 07-03-2002 12:40:36
Its a short term fix but if its orings on sleevesbit will work. Ive got one i done 3 years ago i just check my oil level every time to see if its high so far so good.
wferla
07-04-2002 05:35:36
 Re: Re: Re: 580 B has antifreeze in the oil in reply to Bars leak, 07-03-2002 17:34:09
Hi Bars,
I did not understand your comment. What was your temporary fix for a sleeve o ring leaking?
Thanks Willie
jake
07-04-2002 09:03:23
 Re: Re: Re: Re: 580 B has antifreeze in the oil in reply to wferla, 07-04-2002 05:35:36
Odd way of posting, Barrs leak is a stop leak product. Do a Google search for info on the product
