400 case transmission
Earl Lintz
07-04-2002 08:14:38
Help!!! I was driving the tractor when the transmission locked up. After opening it up, I found a piece of plastic that looked like it might have been a bushing, wedged between range drive gear. I looked in the manuel and can't find where it came from. I can't find where it came from in the transmission either. Anyone know anything about this??? Thank you.
Farm-Al
07-05-2002 04:34:05
 Re: 400 case transmission in reply to Earl Lintz, 07-04-2002 08:14:38
Earl, Check for a plastic oil slinger down in the lower front part of the transmission, used to find a lot of them broken. Al
Joe (Wa)
07-04-2002 18:17:36
Hi Earl, Don't know about the 400 but 300 series has a plastic speedometer drive gear in the transmission. Joe
DKase
07-04-2002 15:55:49
Which 400 are you working on? Check the reverse idler shaft very close. I have taken plastic parts off that shaft in a 930. I don't know if they had plastic in a 400 or not.
bob
07-04-2002 14:17:52
WHat color is the plastic and how thick is it. From my work on other tractors I have not seen much for plastic in the trans rear ends. Did it work after you removed i t.
