Case 1190
Dennis Merrell
07-09-2002 09:45:58
Diesel seems to bleed into crankcase. Is this a seal problem at pump? Also,shift lever is sloppy. any ideas?
Elmer
07-09-2002 14:16:30
 Re: case 1190 in reply to Dennis Merrell, 07-09-2002 09:45:58
The lift pump on the right side of the tractor is leaking. It will have a cracked diaphram. The shifter problem is the wore pins in the linkage. I usually remove the 4 bolts and weld every thing together. You have nothing to loose because to fix it any other way is to buy the parts to take up the slop. Keep it near some cold water to cool the weld down so the O rings in the housing don't burn out. Weld a little then cool and repeat.
