Case 485
Slo
07-11-2002 06:01:51
A friend asked me about a 485 Case, the good and bad points. He is looking at buying one. I know nothing about them.
Any opinions on this model? Thanks in advance.
Max
07-11-2002 17:43:24
 Re: Case 485 in reply to Slo, 07-11-2002 06:01:51
You could try asking how people like their 474 and 484 in the IH board. Almost identical tractor except change in sheetmetal. When they were new, the store I worked at averaged selling about 30 of these units per year and the main warranty item was orings on the pto valve. The clutches seemed to hold up pretty good also considering how those units were used in vineyards and trees out here in CA.
RobertTX
07-11-2002 08:23:27
I have a CIH 585, have been happy with it. The engine is great, wonderful power steering and hydraulics. The range transmission shifts balky, I have been told that is because the gears slide on rails that are above the rest of the transmission and don't get much oil on the rails. I had to replace the large o ring on the lift cylinder and it was a tough job due to the large cover on top of the rear housing. The lift mechanism itself was easy to work on, just a job to get to it. I would buy one again.
