CASE SC Correct tires
Mike
07-16-2002 08:45:28
I own a Case 41' SC looking for the correct tire size for the front & rear tires
rear tires now are 11.2 x 38
front are 5.60 x 15 auto tread
CASEPOWER
07-16-2002 10:47:15
 Re: CASE SC Correct tires in reply to Mike, 07-16-2002 08:45:28
for 1953 Book says rear 10.00x38 Front 5.50x16
But for 1942 10.00x26 or 11x26 rear
and 5.00x15 fronts.
Jim White
12-11-2004 09:24:10
 Re: Re: CASE SC Correct tires in reply to CASEPOWER, 07-16-2002 10:47:15
Require 11x26 tier, new or good used tier is suitable. Hope to hear from someone. Thanks. Jim
John H
07-16-2002 18:39:55
Jonathon, are you sure the SC had 26" tires? Peter's book says the S had 26 " tires. My Uncle Jake had two 41's that he bought new with the solid rims and they were both 38" rubber. The two that were at the Summer Case show both had 38" rubber on them.
Thanks.
CASEPOWER
07-16-2002 19:31:22
 Re: Re: Re: CASE SC Correct tires in reply to John H, 07-16-2002 18:39:55
That's why I wrote that it was from the book. I thought it might be a typo myself, but that is what it says for the S and the SC. It does say the wheelbase is different and the SC is adjustable rear tread so I know they got part of it right.
Leroy
07-17-2002 02:56:34
 Re: Re: Re: Re: CASE SC Correct tires in reply to CASEPOWER, 07-16-2002 19:31:22
The S is a standard tread(wheatland) type and the SC is the row crop, standard tread on all makes used a smaller wheel diameter than the row crop versions, That tractor should be 5:50x16 front with 10X38 rear that translated to the new sizes is 11.2X38, the 11X38 is now 12.4X38, the 12X38 is now 13.6X38, a 10.00X38 is real old size that would more equal 13-14.9X38
Brutus
07-28-2002 07:55:18
 Re: Re: Re: Re: Re: Re: CASE SC Correct tires in reply to CASEPOWER, 07-17-2002 08:33:30
The build sheet for my 41 SC ser. 4500477 shows 9x38 rears and 500-15 fronts this tractor was made Nov. 1940. 11.2x38 [10x38] is about as close as I can get. If someone has earlier SC please let me know. Ph. 507-368-9497 late P.M. central.
John H
07-16-2002 10:45:44
They came standard with 10 X 38 and 5.50 X 16 on the front. Can't say for sure about all but we used the three rib design on the front and the 10" were all switched to 11" when it came to replace them. Better traction.
Thanks.
