Case 900LP pto
Rick
07-16-2002 14:26:11
I traded two just winged calves for this tractor with only 4909 hours on it. The PTO will not disengage when you lift the lever it makes a low grinding noise. A friend of mine took the cover off and said the power take off is trashed and it will cost around 1500.00 to fix it. is this about right? and is this something a avg. person could fix?
caseman-d
07-17-2002 17:55:25
 Re: Case 900LP pto in reply to Rick, 07-16-2002 14:26:11
Should be able to pick up a used unit for less than that. Not sure if the 500 has the same pto or not. I do have a pto for a 500 in unknown condition. Seems to go in and out ok, just never had the tractor going to see if it works. The one on my 900 runs all the time, guess my brake may be worn out on that one
caseman-d
