830 diesel problems
howard
07-17-2002 18:31:17
A friend got an old 830 diesel and wanted me to get it running. I changed filters and fluids but when it started it wants to run full throttle. The linkage appears to be hooked up and working properly but the only way I can shut it down is to stop up the air intake. Any ideas?
RoyG
07-17-2002 19:15:27
 Re: 830 diesel problems in reply to howard, 07-17-2002 18:31:17
The rack in the pump is stuck from setting- 9 out of 10 times you can unscrew the cap off of the rack at the front of the pump and get it freed up.
If you can not get it to move in and out by taking the cap off the front of the pump then you will have to have a pump shop go into the back of pump to free it up.
