Case 930 fuel filters
Ryan
07-20-2002 22:44:21
Can anyone give me a good number on the primary and secondary fuel filters on a diesel 930 case tractor? This would be around a 64 I believe. It has a hand clutch if that helps. Mine had co-op filters and only one had a number. For some reason there was no listing for fuel in the books. Thanks.
Ryan
DaleIN
07-22-2002 09:30:22
 Re: Case 930 fuel filters in reply to Ryan, 07-20-2002 22:44:21
Ryan, if the filters are inside a canister, order filter numbers A7627 & A21141. Also, the final filter (important, I think its in a bracket close to the inj pump) is A57228.
If you have 2 spin-on filters instead, order A41745 kit (set of 2, includes both primary & sec)
Hope this helps, Dale
