Case 310 wont start
charles szymcik
07-22-2002 12:13:41
I have owned a 58 Case for a year,started fine all winter. The other day I went to start it and nothing. Hooked a 6 volt battery charger to bat and it indicates a full charge. There is currently an 8 volt battery and voltage regulator installed. tried to jump start with booster on charger and get clicking sound from regulator. would this indicate a bad voltage regulator.
Thanks for you help. Chuszy
chuszy
07-23-2002 19:32:43
 Re: Case 310 wont start in reply to charles szymcik, 07-22-2002 12:13:41
This 310 is a utility tractor and is 6 volt. One thing I failed to mention is the previuos time I ran it the gas gauge was reading full when it was nearly empty.
Thanks for your reply
Chuszy
caseman-d
07-23-2002 18:06:21
Thought the 300 series were 12 volt, am I wrong???
caseman-d
Lincoln
07-23-2002 20:31:48
 Re: Re: Case 310 wont start in reply to caseman-d, 07-23-2002 18:06:21
My 1956 Case 310 is six volt.
dave
07-25-2002 13:54:45
 Re: Re: Re: Case 310 wont start in reply to Lincoln, 07-23-2002 20:31:48
My 310B Utility is a 12 volt. Could be Case installed a 12 volt on the Utilitys
