1570 hydraulics help
Jeff
07-26-2002 15:31:26
I bought a 1570 and hydraulic filters pressure went into the red so I changed filters.Every thing was fine for about twenty minutes then filter pressure is back in red. Took filters back out filters still look new so put them back in and filter pressure stays in the red and trnsmission pressure goes from green to red and tractor will move for a couple of minutes fluid is full.Has anyone experienced this all help is appreciated.
John M
07-27-2002 20:52:32
 Re: 1570 hydraulics help in reply to Jeff, 07-26-2002 15:31:26
Are hyd's noisey? Does tractor move? Does steering work? Try tractor without hyd filters, I've seen new filters look good but still be plugged. In top of filter cavity there is a relief valve held by two bolts, take it out & inspect. Suction screen/tube could be plugged with brake-difflock-pto plate linings, drain oil and remove trans shift cover. This will allow you to inspect screen at bottom of trans. You could also have a failure in charge pump or seals, which can be removed to check.
Jeff
07-30-2002 10:54:46
 Re: Re: 1570 hydraulics help in reply to John M, 07-27-2002 20:52:32
the tractor moves for about two minutes when first started and everything works then nothing hydraulics are a little noisy.I checked relief valve and tryed with out filters and still acts same way.I am not sure where trans shift cover is my manual dont show where it is thanks for the help.
