1950 Case dc
Joseph M.
07-27-2002 14:32:58
Why does my 1950 Dc leak gas when I start it and sometimes it leaks when it is not being used?
Thanks
Seamo
07-27-2002 15:41:51
 Re: 1950 Case dc in reply to Joseph M., 07-27-2002 14:32:58
Joseph. The carb has a vent hole on the btm to let excess fuel out when you choke to start. If it runs out sitting still engine off,You either have some dirt or rust getting into the needle and seat or maybe the float could be hanging up.Have you cleaned the carb and put a kit in it??Is there dirt in the sediment bowl?Earl in Illinois
Joseph M.
07-27-2002 20:53:47
 Re: Re: 1950 Case dc in reply to Seamo, 07-27-2002 15:41:51
I was going to clean it out some time this next week.. What kind of kit are you talking about?
Seamo
07-28-2002 08:47:26
 Re: Re: Re: 1950 Case dc in reply to Joseph M., 07-27-2002 20:53:47
When you clean a carb you will need a carb repair kit. If you dont replace needle and seat you will need the gaskets.
Joseph M.
07-28-2002 21:28:59
 Re: Re: Re: Re: 1950 Case dc in reply to Seamo, 07-28-2002 08:47:26
Thanks!
