Case 1070, clutch problems
Charles
07-27-2002 20:19:34
I have a 1070 Case that has lost reverse and either jumps when you let out on the clutch or bogs down and kills, but it seems to run fine in high range. The clutch has been adjusted and the hydraulic oil level is fine. It also does not have enough hydraulic pressure to lift the wings on a 16 ft. mower when hot. Does this sound like a hydraulics problem or transmission and clutch.
Thanks,
Thad
07-28-2002 04:41:48
 Re: Case 1070, clutch problems in reply to Charles, 07-27-2002 20:19:34
Sounds like you have a powershift tractor. Generaly when it kills the engine or bogs down its a stuck valve in the powershift valve body. May be possible to clean itup and get it to stay freed up. I have been in many others that have had a piston lodged in c2 or c3 clutch packs. So what im saying is could be several things. Hyd get weak when hot sounds like a weak pump no it shouldnt be causing the clutch problem good luck.
John M
07-27-2002 20:58:15
Powershift or 8spd/dry clutch? What year is tractor?
Charles
08-09-2002 07:24:55
 Re: Re: Case 1070, clutch problems in reply to John M, 07-27-2002 20:58:15
It's a 12 speed powershifter and as far as I can tell the year is 1970, ser. #8654015, Model # AGRI KING 1070..... ....Thanks.
