Case 430 wiring harness and pto shaft.
Greg Grimmett
07-29-2002 13:15:23
Does anyone know where I can buy parts for a case 430? I need to replace the whole electrical wiring harness. Also the pto shaft, brakes and associated gaskets with the R&R of this part.
Greg Grimmett
08-01-2002 11:04:54
 Re: Re: Case 430 wiring harness and pto shaft. in reply to Tom, 07-31-2002 22:19:02
I am looking for the following parts.
Oil pan gasket
engine gasket around clutch
clutch & clutch plate (replacing the clutch)
throw-out bearing
brakes for rear
thermostat
radiator cap
pto shaft
pto gasket around plate
exhaust manafold
mike
08-24-2002 14:50:28
 Re: Re: Re: Case 430 wiring harness and pto shaft. in reply to Greg Grimmett, 08-01-2002 11:04:54
have you tried Used Tractor Parts in Manitoba, Canada? They have a web site and their prices are excellent
Dennis/Ohio
07-29-2002 19:13:45
 Re: Case 430 wiring harness and pto shaft. in reply to Greg Grimmett, 07-29-2002 13:15:23
Hi, I have an opinion about brake parts on a 430, Case parts only... Wiring isn't hard if you look at it one wire at a time and have a wiring supplier for plug connectors etc. I guess thats why they call it an opinion....Dennis.....
