Case 310-B-L Hydraulic Fluid Leak
steve
07-30-2002 05:50:06
I just changed the oil throughout the tractor based on quantities recommended on this board. The problem is now I have a significant hydraulic oil leak occuring where the bell housing meets the engine. As was recommended I put in about 14 quarts of fluid, however when I drained the old fluid before this only about half this amount came out. FYI, the tractor has the triple range tranny, no shuttle, and no hand clutch. As a result I have several questions. Is the leak occuring because I added too much fluid? or is there a leaky seal or gasket and the reason it didn't leak before was that the fluid had drained down to this point? Also, how important is the level of this hydraulic fluid? Can I run it for the remainder of the summer with half the recommended amount without risking damage?
