18-32 case
BOB
07-31-2002 14:40:56
overhauling a 1927 18-32, having trouble with the exhaust blowing back thru the carb. Have put new valves, rings , sleeves and had the carb and mag worked on. Sure need some help on this one. Thanks, BOB
Don L. @ Rusty Acre
08-02-2002 05:41:01
 Re: 18-32 case in reply to BOB, 07-31-2002 14:40:56
I just had a head redone for a 18-32. My head had 30 degree seats in it. Most replacement valves were 45 degree. They need to match.
Don L.
CASEPOWER
07-31-2002 18:51:52
Sure does sound like the valves are to tight or not seating. The only other thing wound be valve timeing.. CASEPOWER
BOB
08-01-2002 09:38:35
 Re: Re: 18-32 case in reply to CASEPOWER, 07-31-2002 18:51:52
Thank's CASEPOWER, I am thinking that the valves were not ground in properly. Will check everything that you mentioned.
