Case SC
Terry (IN)
08-03-2002 13:33:47
I have recently purchased an SC that the owner said he brushed hogged with, and it started knocking, so he shut it off right away, and let it sit for about a year. I havn't looked into it very close, but noticed the front pulley is crooked, and has a set bolt. Is this pulley pressed on, and could that be the knock? I am unfamiliar with case tractors, but like this tractor so I bought it. I currently own a 23 fordson f, 47 ford 8n, IH H, and an unstyled AC WC.
Mike Schotte
08-04-2002 18:18:31
 Re: Case SC in reply to Terry (IN), 08-03-2002 13:33:47
Hi Terry,
The pulley you are speaking of with the adjustable side is the water pump pulley. The adjustment bolt is so that either you can use a different width belt, or make it so a longer belt rides in the correct position on the pulley if you can't get the adjustment you need by moving the generator alone.
As far as your knock question- I can't answer you. If it's crooked, then you should be able to tell if it's hitting. I know the fan blade tolerances are pretty close on my '49 SC... but a fan hitting doesn't sound like an engine knock.
Let us know what you find out.
Happy Tractoring! -Schotte
Terry
08-06-2002 19:43:00
 Re: Re: Case SC in reply to Mike Schotte, 08-04-2002 18:18:31
Mike, I wasn't clear on which pulley. This is the crank shaft pulley. It looks like It's pressed onto the crank with a set bolt on the side that tightens against the crank. Thanks, Terry (IN)
