Can I fix loose steering box on VA?
Dale Olson
08-05-2002 13:56:11
I've got quite a bit of play in the steering box of my '48 VA. Does anyone know if there is an adjustment that can be made to take some of that out? If no adjustment, are new (good used) parts required?
Thanks for any info
Bill Hires
08-05-2002 14:56:07
 Re: Can I fix loose steering box on VA? in reply to Dale Olson, 08-05-2002 13:56:11
Main steering gear worm shaft end play adjustment. Remove cap screws retaining worm shaft column to transmission housing cover. Remove column and steering worm and shaft assembly. To reduce end play, remove cotter pin and tighten worm retaining nut sufficiently until worm shaft has zero end play, but rotates freely. Relock nut, install cotter pin and reinstall column and steering worm assembly, using a new gasket between column and transmission (gear housing) cover.
Worm wheel (gear) shaft end play is controlled by adjusting screw which is located on left side of trasmission(gear housing) cover. To adjust, loosen adjusting screw locknut and turn adjusting screw clockwise to remove all of worm gear end play, without binding. Relock set screw nut.
Gear mesh excessive backlash between worm and worm wheel may be corrected by meshing an unused portion of the worm wheel with the worm. Remove steering pitman(drop)arm from worm wheel shaft. Rotate steering wheel until worm wheel shaft has moved approximatel 1/3 revolution. With front wheels in the straight ahead position, reinstall steering pitman(drop) arm to worm wheel shaft.
JI Case I&T Shop manual C-201
