Case 830 carb.
JE
08-06-2002 08:25:01
What is the corrct LP carb for a 1964 case 830? I have two different types. One has some sort of diaphragm on the inlet side an small tubing coming off of it to the upper part of the carb and off to somewhere on the regulator. It also has a separate choke valve. I think it came off of a 1030. The other carb I have is much simpler and has no separate choke valve or extra tubing on it. Any info on this would be much appreciated. I'm converting my tractor back to LP as it was originally form the factory.
scott AR
08-17-2002 17:50:39
 Re: case 830 carb. in reply to JE, 08-06-2002 08:25:01
The first one is probably an Ensign and was probably original equipment if it came from the factory. The other one may be an Impco, which you can still get parts for, or it could be a Century. Either way I would go with an Impco regulator.
