400 CASE
Doug
08-06-2002 21:24:44
Does anyone know if a inline fuel pump off a 800 or 830 Case diesel fit a 400 diesel?
buckmaster 700
08-08-2002 19:20:01
 Re: 400 CASE in reply to Doug, 08-06-2002 21:24:44
yes it will fit you need the lines also
Doug
08-08-2002 19:56:48
 Re: Re: 400 CASE in reply to buckmaster 700, 08-08-2002 19:20:01
Buckmaster700,do you think the inline pump would give more fuel? The pump on the 400 now is an American Bosch,it has a 7.5 mm head and is a rotary pump.
buckmaster700
08-09-2002 18:38:57
 Re: Re: Re: 400 CASE in reply to Doug, 08-08-2002 19:56:48
if your pump is doing well stay with it .power cell engines dont make alot more power from turning the fuel to it .plus you run a chance of cracking a head. do some port work and cam change if you want more power
