996 HYDRAULICS
STEVE CUNNINGHA
08-11-2002 10:17:06
Having a bit of a problem with my 996 raise and lower function.As soon as I start up the links automatically lift,with a implement on it is ok on tick over but as soon as I rev up it lifts again with the lever in the lower position.Any experts out there that can help me out ?
James
08-11-2002 12:44:50
 Re: 996 HYDRAULICS in reply to STEVE CUNNINGHAM, 08-11-2002 10:17:06
The 'expert' is Elmer, he posted right before you saying he's going to be away from his computer for 1 week.
Sounds to me like your Dial Pointer is set on TCU/EXT. If so, you need to move it to the center position which is Height.
The dial pointer is on the right rear behind your rockshaft control. It has 3 positions: depth, height, TCU. In order to move it from one to the other, your rockshaft must be all the way up.(Above the normal full up position) Hold the rockshaft control lever to the rear against the spring, and the rockshaft will lift to the necessary height to switch the pointer.
