530 CK. Need help with steering shaft seals
AL 2
08-13-2002 13:24:13
I have to replace a seal on the steering shaft on the pump just below the steering wheel. Parts 16,17, 18, & 19 in the parts book. Does anyone know if I can do this after removing the steering wheel only or will the pump have to be removed from the tractor? Removing the wheel will be a big job itself as it is seized on the shaft. A felt bushing and water seal are not available from Case in Ontario. Any help or suggestions are appreciated. Thanks. Al.
