Belt Pulley Pump HELP !!!
G autry
08-17-2002 06:09:44
I have a 1944 VAI, I took the pump because it would not hold pressure. if i had a 3pt hook to the disk it would lift it fine but as soon as i released the control it bleeds off. that was the the problem that inticed me to remove trhe pump and take it apart. i took it off and cleaned the inside, now i can't get it to lift any weight. the ram will lift if no weight is on it. PLEASE HELP not sure if i got all the parts back in the correct place.
