580b ck
Shan
08-18-2002 07:10:22
I am trying to get the right side brake cover off to replace the seal and bands. There is a smaller box mounted to the outside of it (differential lock?). Do I need to get the smaller box off to get the brake housing off? If so how. It is kicking my but. Also seam to have a leak that is dripping trans. fluid into the clutch housing what is that? Please help, its Sunday and can't get a manual today.
Answerman
08-20-2002 15:11:22
 Re: 580b ck in reply to Shan , 08-18-2002 07:10:22
The drip is your front trans seal, will have to pull the motor, you can do it. Replace the clutch while your there. There is a allen bolt on the outside of the diff. lock casing have to look for it.
sHan
08-18-2002 07:16:11
just woundering about your name mine is alao shan i use it as sHan online since i have an farmall H also have a JD G but it dident fit into my name anywhere have a good day.....sHan
