Case 530 Power steering
Greg Falco
08-19-2002 19:40:31
I just purchased a 1963 Case 530CK that does need work, but what doesn't? The power steering doesn't work, and there seems to be no left or right "hydraulic stop" since the wheel's don't turn. The resevoir is full, no major leaks in the system and even with the wheels off the ground no turning motion, but short of restricting circulation the P/S pump it doesn't seem to "Dead Head". I'm familiar with Automotive Systems but Case Tractors are a new for me. Any suggestions / ideas would help.
Thanks,
Greg
Scott AR
08-20-2002 19:05:18
 Re: Case 530 Power steering in reply to Greg Falco, 08-19-2002 19:40:31
If the pump is pumping and a CK is the same as a Utility, I would guess the valve that senses direction from the hand pump is stuck. It is located under the fuel tank.
