1070 clicking
Woody
08-20-2002 17:47:23
I hope somebody can help! My 1070 will click when I try to start it. I have all gears in N, it will click on each turn of the key. After maybe 10-15 trys it will make contact. Is this the solenoid or starter, or is it a bad connection in the N sensor. I thought I would buy a new solenoid, and if that didn't fix it, have the starter checked. Any ideas would be appreciated.
j
02-26-2003 12:51:23
 Re: 1070 clicking in reply to Woody, 08-20-2002 17:47:23
i had this problem on my 1070 also. turned out it was a bad ground.
Gerald Michaels
08-20-2002 18:24:31
It's the solenoid,you can remove it from starter & take it apart & fix it real easy. The copper bolt that comes out of solenoid gets burnt & dopesn't make contact with the disc. Just turn copper bolt 180 degrees & will be like new. Saves $25 or $30. Them old cases are tough machines.
George
08-21-2002 05:04:21
 Re: Re: 1070 clicking in reply to Gerald Michaels, 08-20-2002 18:24:31
If you short (jump) from the battery wire to the small terminal on the solenoid; and it starts then look at the switch circuit. My 830 had corroded connector.
