Hello again Dave, I'll be happy to help you with any questions you have during the carb rebuild. As far as replacing the choke shaft- this is only necessary if it is excessively worn or bent. The brass shaft is softer than the cast iron body, so the shafts will decrease in diameter over time. My old shaft was pretty worn out at the ends. I only think it's a problem if it's loose enough to allow air to leak into the throat of the carb. Most of the kits provide a wool "packing". Not sure- but this might be for sealing around an old shaft, if necessary. Let me offer you some pieces of rebuild advice that I learned by trial and error on my carb: 1) Make sure the float level is adjusted right. The measurement that they give you from the top of the carb body to the bottom of the float is for the CLOSED positon (carb held upside down)- NOT the other way around! 2) Make sure the float doesn't have any pinholes in it. I accidentally creased my old float while adjusting the levels... and it made a pinhole so small it took several weeks to fill up with gas and flood the carb. 3) Trace your old gasket onto the new gasket, if possible. I've always had to cut away portions of the gasket around the floats to get them to clear- as the new gaskets have "D" shaped float holes instead of ovals. (I suppose you could install the gasket before you mounted the floats- but that seemed stupid to me.) Make sure the floats are still free to travel after re-assembling the carb. 4) Always install the needle valve spring, and get yourself a good inline fuel filter to protect the nice clean carb you just built! 5) Make sure the drain hole is clear in the bottom of the intake bowl. This will allow gas to run out so you can see if the floats are sticking, or if the tractor is flooded due to excessive cranking. As far as your question about the sediment bowl/fuel strainer... I would pull it off for now. I don't have one on my tractor, so I can't give you any advice on troubleshooting them. What I can say is... it's not worth burning up your tractor by ignoring a gas leak. Good luck, and keep me posted on how it goes. -Schotte
