CASE LA vs Deere R
robert
08-25-2002 14:36:27
Went in a local Fun Pull and pulled against Buddy's stock R Deere both weighed the same.Case died out long before R. After found governor rod out by nearly an inch. will try again. What is the usual outcome of these 2 particular tractors at other pulls? Need to warn Buddy defeat is possible!!If possible!!Feel free to make up LA success stories!!
Don L. @ Rusty Acre
08-27-2002 04:15:05
 Re: CASE LA vs Deere R in reply to robert, 08-25-2002 14:36:27
where you in first gear? It should spin out before it dies. Any fluid in the tires? What weight class were you in ?
don L.
Jim M
08-26-2002 17:40:22
If you want a chance make sure your drawbar is as high as his. I have cousin with a LA LP and 1st time out got 1st in 9500 stock class.
Don L. @ Rusty Acre
08-26-2002 17:36:18
don L.
robert
08-26-2002 18:32:52
 Re: Re: CASE LA vs Deere R in reply to Don L. @ Rusty Acre, 08-26-2002 17:36:18
Hi Don.I was in first gear so was R.We both weighted 7900lbs.My draw bar is indead much lower.As stated governor was terribly out of adjustment.Question is,have you seen LA's outpull R's in field class equal weight pulls??
deerehater
08-28-2002 14:03:04
 Re: Re: Re: CASE LA vs Deere R in reply to robert, 08-26-2002 18:32:52
what year is your la, earlier la's had a faster low gear than later models. deeres do better a tractor pulls as a rule for one reason, they are slow. if you have the chance, get this r to farm against your la for a day and then see the difference in how many more acres the la covered.
remember, horsepower is lbs pull AND SPEED while pulling is just pull.
dave
Jim M
08-27-2002 14:37:31
Robert he will always beat you with a higher drawbar.
robert
08-27-2002 17:04:35
 Re: Re: Re: Re: CASE LA vs Deere R in reply to Jim M, 08-27-2002 14:37:31
Then I MUST make the "highest draw bar of them all". Actually I went with a home made height increasing device to add 4 inches,but the monstrous hook wouldn't fit in it so I had to go straight off with a clevis. Will use the low draw bar and out of whack governor adjustment that I failed to notice as an excuse for loss till next time! Thinking of adding fire-works down muffler for a showwy pull next time,to psych out that evil "R"...!!!
Jim M
08-28-2002 17:52:05
 Re: Re: Re: Re: Re: CASE LA vs Deere R in reply to robert, 08-27-2002 17:04:35
Make yourself a clevis lip to bolt on top of the drawbar with a piece of flatbar and a 2" piece of square stock. Then make as many flatbar spacer to sit on top of the drawbar to get your height. Works on my Case short drawbars
cb
08-27-2002 07:50:15
Just my thoughts.. I think the ones that win in tractor pulls are the tractors that are the best running or have had the most money spent on them...
A JD had a low low gear but Case's had much more torque.
If your Case tractor stalls out before you spin the tires and throw some dirt you to work on it.
