Can a DC4 be a competitive puller???
Jeff
08-25-2002 18:30:23
Can a DC4 be built to win in the 5500lb farm stock class? Any info would be great!!!
clint
08-27-2002 12:53:07
 Re: Can a DC4 be a competitive puller??? in reply to Jeff, 08-25-2002 18:30:23
With the front axle being back under the front end, it does pull up a little quick. A shortened drawbar would help with this issue. I pull a DC3 with an adjustable row crop widefront end. It is quite competitive with the engine built up right. I do have better luck in the 6000lb class because you can put some extra weight on the rear axle. If built up correctly the DC's are a great tractor. I really like the wet clutch.
Jim M
08-26-2002 02:38:10
I pull a DC3 and know of many others. The DC4 has a different front axle is all. They can be made to be good pullers it just depends what classes and how much money you want to spend.
John H
08-25-2002 18:43:41
I can only talk from farming around them. They would be light on the front in pulling as they like to come up when the pull gets really hard. I've never seen one at a tractor pull.Someone else may have tried to pull one and be able to give you some info.
Thanks.
