1951 DC-3 Carburetor Problem
Chris Hibbert
08-26-2002 07:06:44
My DC-3 was running well a few weeks ago - all of the sudden, it started acting differently. Here is what it was doing:
It would basically idle ok maybe a little more variation in rpm at idle than before when it was running well. Occasionally even at idle, it would cough and sputter one time then level out and not do it again for maybe 45 seconds. Under load, it bucks and sputters almost continuously, and can't pull it's weight up a hill without almost dying.
I bought a rebuild kit (which as it turned out didn't have many parts I could use in it) - I replaced the float rod, idle adjusting screw, needle, and seet plus gaskets. I didn't really change anything by doing this - it still runs decent at idle but won't pull itself out of a wet bag (and it had absolutely tons of power a few weeks ago) - I have noticed that the main jet is buggered up pretty bad and looks as though it can't be pulled from the bowl assembly as the screwdriver slot has been busted of (trying to remove it I assume) can a buggered up jet cause what I am experiencing? Also the air tube that goes up to the intake gets ice cold when it's running now and sweats (it could have been doing this before but I never noticed it).
I am purchasing a completely re-built carb from this website - do you all thin this will fix my problem or am I looking in the wrong spot?
P.S. Distributor cap is new as are the plug wires and it appears that the points and condensor are new too.
Any help would be greatly appreciated. I live in Thornville, OH
caseboy
08-28-2002 13:52:51
 Re: 1951 DC-3 Carburetor Problem in reply to Chris Hibbert, 08-26-2002 07:06:44
i would run it with the valve cover off and see if the valves are trying to stick. cases of the thirties throught the mid fifties had lots of sticky valve trouble.
good luck
dave
Jim M
08-26-2002 17:36:39
If all else fails try and advace the timing some.
Old Iron
08-26-2002 16:56:02
You might check for an intake manifold leak.
Will
08-26-2002 07:57:59
Could be water in gas tank or hole in cap pluged.
Mike Schotte
08-26-2002 07:31:17
Chris,
My vote is that the tractor is starving for fuel. After I originally got mine running again after 12 years of sitting, it would idle just fine, but would sputter and backfire if I tried to use it under any load at at all.
Turned out that there was an obstruction in the 90 degree elbow out of the fuel tank. The tractor was running on the amount of gas stored inside the inline filter. It would do fine when the filter body was full, but would die when I had depleted the gas and it couldn't refill fast enough. Let us know what you find out.
Good luck, -Schotte
