580 Backhoe
Jeff's 40
08-26-2002 14:20:19
Today I found a Case 580 backhoe (or so I think) The serial tag on the frame has model 33 serial number 4162777. The serial tag on the backhoe has the same model 33 and the serial number 4136937. The only place that says 580 is whats left of a decal on the backhoe boom. It has a G188D engine S/N 2646384 that has one sleeve removed the rest of the engine has been completly disassembled. The overall condition of this tractor poor but the owner says all the parts are there. It looks like all the rubber hydraulic lines will need to be replaced I have no idea if the trans or rear end are any good. This thing has been sitting like this for atleast 3 years.
Should I run away from this? Is it worth rebuilding? Are the parts worth somthing?
Any advice would be appreciated
Thanks
Jeff
Dennis/Ohio
08-27-2002 03:52:41
 Re: 580 Backhoe in reply to Jeff's 40, 08-26-2002 14:20:19
Hi, You found a 580CK and parts are available. Used parts are valuable but with all your labor parting it out, you may collect $5000. A complete restoration, I'd figure $10,000 in parts and 2 years your labor. Wouldn't be worth much done but you'd have a like new machine to use...Dennis...
Jeff's 40
08-27-2002 06:18:17
 Re: Re: 580 Backhoe in reply to Dennis/Ohio, 08-27-2002 03:52:41
Dennis,
Thanks for the information.
Jeff
