1962 Case 930 CK question
Jim Weatherby
03-13-2006 05:56:31
Hi, Can some one tell me if the hydraulics use a seperate oil supply, or does it use the trans/oil? Thanks, Jim
c hess
03-13-2006 20:32:48
 Re: 1962 Case 930 CK question in reply to Jim Weatherby, 03-13-2006 05:56:31
9turn 30ck serial no8347136 has common sump with filter on left side-holds 16 gal
Jimmie D. Phelps
03-14-2006 20:54:47
 Re: 1962 Case 930 CK question in reply to c hess, 03-13-2006 20:32:48
You are right if it was a eight speed 930. you are wrong if it is a six speed. I don't believe they come with a eight speed until 1964 or 5 I still don't think 1962 had a comfort king.
Jimmie D. Phelps
03-13-2006 20:13:39
Are you sure your talking about a 1962 930? I thought they came with a Comfort King in 63.It sounds like your talking about a Comfort King. Either way the Hyda is built in the rear cover of the Tran end plate. Tran and hyda oil -SEPERATE. Hyda--use case Hi-teck or type A auto trans oil. I have a 1966 CK that came with tch in trans and I changed to 80-90 hypoid. Had 2000 hrs when I changed No trouble in the next 6000 hrs. still runs great and have never touched the rear end.
Jim Weatherby
03-13-2006 20:37:34
 Re: 1962 Case 930 CK question in reply to Jimmie D. Phelps, 03-13-2006 20:13:39
According to the serial number it's 62, or I misread it. Either way it is an early Comfort King. I appreciate the information. Thanks, Jim
Jimmie D. Phelps
03-13-2006 11:41:14
You are wrong. Seperate oil supplies. No filter tran. some used 80-90 in tran-diff. some used tch or now latest case hyda oil and hyda had its own edgewound filter and used tch and now latest case hyda oil.
Jim Weatherby
03-13-2006 12:42:00
 Re: 1962 Case 930 CK question in reply to Jimmie D. Phelps, 03-13-2006 11:41:14
Well, I just pulled one of the ends off so I can put on some Pioneers and what looks like ATF ran out of the hose, so this must have a seperate oil supply. Is it the cast tank under the LH floor board? Jim
c hess
03-13-2006 07:07:10
930 hyd an trans are same checked an filler at rear of tractor-16 gal capacity-case tch oil
Jim Weatherby
03-13-2006 07:29:59
 Re: 1962 Case 930 CK question in reply to c hess, 03-13-2006 07:07:10
Much appreciated!! Jim
