Case Model VA Easy Ride Seat
Steve Staysko
08-26-2002 19:41:33
I'm currently restoring a 1956 Case VAC-14 with an Easy Ride Seat and I'm having the hardest time sourcing part VTA-3348(2)these are the large rubber shock absorbers that are located under either side of the tractor seat. Does anyone know were they could be found, mine are badly weathered and need replacing.
jal-SD
08-27-2002 06:27:16
 Re: Case Model VA Easy Ride Seat in reply to Steve Staysko, 08-26-2002 19:41:33
Yep, Min-Kota Repair (38893 County Hwy 14-Ortonville, Mn 56278) has them. Got one for my '54 SC easy ride seat earlier this summer. They are spendy-$125 for my large one. You'll need to send your old bushing to them so they can get the right size & the brass bushing that go inside it, as there are a couple of different sized ones. They also have them for Olivers. Grind the rivets that hold the outside brackets on & keep them-you'll have to use them again. Make sure you make a drawing of how they are attached, so you don't get it wrong when you rivet them back on. Do this BEFORE you take it off the tractor. (Don't even ask why this is important!) They are great to deal with & the product is worth the $. (My $0.02 worth. jal-SD)
info seeker
08-30-2002 10:56:04
 Re: Re: Case Model VA Easy Ride Seat in reply to jal-SD, 08-27-2002 06:27:16
Do you know if they do Oliver seats? The design and application is similar.
Steve Satsyko
09-01-2002 11:48:16
 Re: Re: Re: Case Model VA Easy Ride Seat in reply to info seeker, 08-30-2002 10:56:04
I phoned Minn-Kota at 320-839-3940 and they do reproduce the rubber parts for the case seat. I'd suggest that you phone them and ask....
