310 case dozer
Brian
08-27-2002 17:00:02
I am looking for front idler wheels for a case 310 dozer. Need ones with the bolt that goes through and has nuts on each end. Looking for the complete unit bearings etc. Not interested in a worn out one, I already have that.
Terrance
08-28-2002 12:43:17
 Re: 310 case dozer in reply to Brian, 08-27-2002 17:00:02
You can use the later model Case 350 idler mounting it in the 310 brackets or you can adapt the whole 350 idler and brackets to fit the 310. Berco and I-Trac both sell 350 idlers for Case 350's with or without the brackets. I doubt you will have much luck finding a servicable 310 idler.
Good Luck Terrance
