Case 511-b Speedometer/ Hour meter
Jeff
08-29-2002 18:21:47
I think i need a new speedometer cable on my 500. It doesn't spin at the top of the cable. Are they expensive? Are they hard to replace? Also, my hour meter doesn't work. Any help would be greatly appreciated!
Jim M
08-31-2002 18:20:34
 Re: Case 511-b Speedometer/ Hour meter in reply to Jeff, 08-29-2002 18:21:47
Check with your lacal auto parts store for a speedometer cable repair kit. If the cable housing is OK that should fix you up.
Terry Nelson
08-29-2002 19:11:30
Jeff, I can't answer your question but I would sure like to know where I can get the instrument cluster on my 511B rebuilt. The speedometer doesn't work and the Tachometer needle is missing or is broken. I think they are made by Stewart Warner but am not sure. Stay in touch. If I find out anything I will contact you.
