900 case power
kd
08-31-2002 09:00:03
How much power can you make out of a 900 diesel with 504 cubic inch .
JEAN CLAUDE MARLEAU
10-20-2002 20:44:20
 Re: 900 case power in reply to kd, 08-31-2002 09:00:03
HI KD JUST WANT YOU TO KNOW THAT I HAVE FOR SALE ONE 504 BDT COMPLETE ENGINE AT A VERY GOOD PRICE IF INTEREST MY E AMIL IS jcmarleau@aol.com
tim
09-25-2002 20:38:34
why do want to mess with a504 when a 451 from a 1170 or 1175 will bolt right to a 900 trans? all you need to do is drill the side of the block where the steering shaft goes. you can get 250 hp easy with this set up , more than your trans will handle on continuous use.
Alan R. Brayshaw
07-02-2004 12:56:54
 Re: Re: 900 case power in reply to tim, 09-25-2002 20:38:34
I have a CASE W36 with a A504 Motor with what I think is a cracked block. Can that 451 bolt up to my trany? I have a torque converter that seems alittle tired as well. IS it better to get a rebuilt,.???
Kase
09-01-2002 16:20:04
You do know a 504 wont bolt in a wheatland rear end.
Ryan
09-01-2002 14:14:15
If you pull the pto out and if it would work in a 930 I would be interested in it. Mine has a plate on it now, no pto.
Ryan
joecool
08-31-2002 19:06:39
It depends on how much money and how many turbos you want to put on it. Apparently you already know that 504 didn't come in 900. You could drill and tap for spark plugs, 4 turbos, alky, and 4-5000 hp. Look at all the big boys.
Jim, I found a good way to loose alot of weight on a 900. Put a L plate on rear and loose pto. Dad found a plate in Portland, Ind.
Jim M
08-31-2002 18:00:01
You could get 220hp if you set it up with 2670 tubo and intercooler and would have a good life out of it. When you exceed the 22 to 1 air to feul mix the life goes down. You want to put more fuel and power put in more air also. If you turned the black smoke feul to it you might get 200 hp out of it.
Zach
09-01-2002 13:39:07
 Re: Re: 900 case power in reply to Jim M, 08-31-2002 18:00:01
the 504 in my uncles 1570 was turing 220hp factory.
