Case LA timing problem
Ap
09-01-2002 19:47:00
Hello, I have a case LA that i am trying to get running. I have a hot mag. I have got all of the correct firing order and new plugs. When i check the firing on the #1 cylinder the mark on the fly wheel is E. My manual says that it should be D. They are fairly close together but how do i go about getting to the D. The tractor is currently blowing flames into the air when you try to start it. Any insight would be helpful
Thank you
Bob
09-02-2002 01:50:44
 Re: Case LA timing problem in reply to Ap, 09-01-2002 19:47:00
Are you changing the timing adjustment just in front of the magneto (ie just behind the govenor)?
From memory you need a 1 1/4" open ended wrench.
ap
09-02-2002 19:33:16
 Re: Re: Case LA timing problem in reply to Bob, 09-02-2002 01:50:44
thanks, I adjusted the thing between the mag and the shaft....and now it fires on D like it says...thanks
