Case LA Needing Parts PTO,HYD
phil
09-02-2002 08:55:15
HI I have recently aquirred a Case LA. I have decided to put a PTO on it as a friend of mine had one he was not going to use. After removing transmission cover to install the PTO shaft found I was missing the shifter fork.
Anyone that may have one I would be appreciativae.
Also looking for a hydrolic system for the LA. I have nothing and need all. I use my tractor for farming as well as show so these systems are highly desirable for me.Also looking for origional gauges.
Any information or parts please contact me at philranch@aol.com please put (Case LA) in tital area as I may deleate.
Will
09-03-2002 17:38:22
 Re: Case LA Needing Parts PTO,HYD in reply to phil, 09-02-2002 08:55:15
Phil, Is the gear that runs the pto in place or is that gone to??
phil
09-03-2002 18:52:48
 Re: Re: Case LA Needing Parts PTO,HYD in reply to Will, 09-03-2002 17:38:22
Not shur if last message got through.
I think all is there except the shift fork to ingauge and disenguge the pto
Phil
