Case 430 hi-range does not work
Bob H
09-04-2002 09:54:31
I'm looking at a Case 430. Lo- range works fine, no noise in any gear. Hi-range does not work. The Hi-lo lever can be moved a little bit, but won't go into hi range. Any idea if this is a simple problem in the cover, or something more involved which will require going into the transmission. This tractor has not been used for a while.
Bob H
