Case 580 B reverse only
Cord
09-04-2002 23:49:48
I have a Case 580 B with the automatic trans(hydrostatic?) that doesn't go forward when cold, and just barely goes forward when it is warmed up. Reverse is fine. Any ideas? Filters, screens, fluid? Thanks.
JEAN CLAUDE MARLEAU
09-17-2002 18:32:57
 Re: Case 580 B reverse only in reply to Cord, 09-04-2002 23:49:48
CORD I GUESS THAT AFTER CHECKING FILTER AND FLUID CHANCES ARE THE PLATE IN TRANSMISSION FOR FORWARD THAT ARE WORN CAUSE YOU HAVE SOME FOR FORWARD ANDC REVERSE BUT WORSE OF ALL INSIDE THOSE PLATE THERE IS A SMALL GEAR WITH I THINK IT IS 10 OR 12 SPRING AND THOSE TINY SPRING ARE BROKEN ANDC YOU CANNOT GET THOSE SEPERATELY YOU HAVE TO BUY THE LITTLE GEAR.
