Case 680 ck
Frank
09-07-2002 14:22:48
Help !Backhoe wont move,it was working fine then started to take off and engage slowly, I backed it up to start digging and tuned it off ,when i came back and tried to move it would not engage at all ,i reved the motor and it was trying to go in reverse but would not ,forward and reverse shifter is v on the steering colum ,its an 1968, anyone have any idea where i can start? If Max is still around i sure could use some advice,thanks Frank
Max
09-09-2002 20:54:59
 Re: case 680 ck in reply to Frank, 09-07-2002 14:22:48
I would first check out the clutch cut-out on the power shift. These were designed to release power to the transmission and apply all that power to the loader hydraulics.
frank
09-17-2002 02:35:46
 Re: Re: case 680 ck in reply to Max, 09-09-2002 20:54:59
thanks max ,nothing but a broken linkage ,long day and no lights,thanks for your help,frank
