Hi,I start by admitting I know very little about tractors. However I have convinced my wife that I absolutely 'need' one :) I have been offered a 1950 Case VA. Its been in regular use until last month when the original owners son (who is over 60 himself) finally broke down and bought himself a nice new JD. The tractor comes with Eagle 3pt and a Wagner (spelling?) loader. The loader comes with both grader blade and scoop. Also included is a rear box scraper. This is exactly the setup I am looking for one of its duties, some infrequent gravel road maintenance. The tractor starts fine and runs without smoke. Oil leakes appear to be minor. The loader seems to work OK too. Now the bad news. This tractor has lived an outdooor life. All sheet metal has ben removed for access. I did see the hood lying off to the side, all red with rust. I need to confirm if the other sheet metal is still available. Much of the paint has peeled and surface rust is everywere, especially on the loader. None of it looks bad, but a good sandblast and new paint job are long overdue. The 3pt lift moved, but only just. The owner thinks it may be low on hydraulic oil because he seems to remember it worked OK. The PTO shaft looks moderately worn, but it turns OK when engaged. I could really use a smaller and more nimble tractor (8n?), but I am guessing that any older tractor with a loader is going to be a *$%^@&* to maneuver. The asking price is $2500. Given that this is California and not the Midwest, running tractors for $500 just arent available :) I suppose I could rent a new tractor for what I need, but where's the fun in that?? Does anyone have any opinions, suggestions or comments? -Colin
