Batteries for 930 Case LPG
Ricky
09-10-2002 06:35:52
The 930 I bought has one huge twelve volt battery mounted in a box on the side. It needs to be replaced. Why would they do that and not have the two six volts under the platform? Is this tractor hard to start? What should I do? Thanks, Ricky
Wayne MN
09-12-2002 09:06:13
 Re: Batteries for 930 Case LPG in reply to Ricky , 09-10-2002 06:35:52
I have two 12 volt batteries hooked up parallel on my 930 diesel. Looks proper and helps crank with all those amps available.
Wayne
Rick in ND
09-10-2002 19:10:32
Ricky, I have 2 930 diesel tractors. Original equipment was 2 6 volt batteries. Each of these batteries is $75 to $80 plus tax. A 950 or 1000 amp 12 volt battery will do a good job of cranking the engine, but will cost what one of the 6 volt batteries costs. They last 5 or 6 years on the diesel engine. The propane engine does not have as high compression as the diesel, so it should be easier to crank over. If you want the tractor to be authentic, then you can use the two 6 volt batteries.
Jason
09-10-2002 08:30:12
I would do a search on 930 and see what you get. If I remember correctly, there are a couple of posts that deal with battery power for the 930. I am trying to restore mine now, and the archived posts have been more helpful than I could have ever imagined. Good Luck
