Case 430 won't start
Greg
09-11-2002 15:00:13
I have replaced the coil and I cannot get a spark out of the spark plugs or the new coil. Any idea's
whip
09-11-2002 17:45:36
 Re: Case 430 won't start in reply to Greg, 09-11-2002 15:00:13
Greg, there is a couple of things to check. 1 do you have voltage to the coil. 2 Is the points opening and closing ,do you have the right gap. 3 do you have voltage at the points when they are open.Hope this will help you .
Whip
Gregg Kuljian
09-12-2002 09:49:28
 Re: Re: Case 430 won't start in reply to whip, 09-11-2002 17:45:36
Water on the inside of the rotor cap is a possible cause. Get the Pertronix points eliminator replacement for $50 or so. It's a great way to eliminate points problems. Good luck.
carol mosher
09-12-2002 10:27:11
 Re: Re: Re: Case 430 won't start in reply to Gregg Kuljian, 09-12-2002 09:49:28
Try replaceing the condenser. Ours did the same thing and the condenser was cracked.
