Case 1390 Hydraulic problem
Phil Leithold
09-12-2002 15:44:51
I have a 1390 case. Had brushhog on and it dropped to the ground. It will not pick it up or even try to pick up. Has anyone got any ideas?
Elmer
09-12-2002 17:57:26
 Re: Case 1390 Hydraulic problem in reply to Phil Leithold, 09-12-2002 15:44:51
Do you still have pressure at the remotes. If so you may have stuck spool valves in the 3 point control valve. You could have a blown piston Oring. Check for pressure first and then get back to me.
